Hi, I'm new here! (and fairly new to electronics)
Here's a arduino shield for a motorcycle inertia dynamometer I've built.
I've got the dyno up and running with just the roller pickup wired into the arduino with a pull up, but I also need engine rpm.
I'm using this software: (works great BTW, and is free)
https://sites.google.com/site/simpledyno/homeMy rpm pickup circuit is based on/copied from this site:
http://www.sportdevices.co.uk/rpm_readings/index.htmThe connector labeled with the lightning is from the spark plug wire pickup, wich is just a coax cable coiled two turns around the plug wire. "-" is connected to the coax shielding. The signal is entering the board on the top layer and is transmitted to the bottom layer by capacitive coupling before it enters the 100p cap.
The connector labeled with the "wheel" is the roller pickup, a Honeywell 1gt101dc.
It would be great if someone could comment on my pcb layout and the circuit;
Anything obviously wrong?
What could be done better?
Right choice of component values?
Thanks!
