Author Topic: Simple power supply or conditioning circuit for decisive power-on edge  (Read 11593 times)
Offline jmbreuerTopic starter
I'm faced with one of those niggling problems where I kinda (think that I) know what the issue is, and how I might fix it in a world where expense would be of no object.
However, I'm fairly constrained financially, so I'm looking for a cheap/simple solution.
I have a device (Hi-Fi DAC, MusicalFidelity V-DAC II  https://www.musicalfidelity.com/uploads/catalogerfiles/v-dacii/4_VDACii_24-96asynchUSB_manual.pdf if that's of any help) that I want to completely power off along with my stereo system when it's not in use. I got some Shelly / Tasmota WiFi power plugs for that.
Now, it turns out, powering up the device by turning on the primary side of its power supply will about half of the time result in an error state where it will output an annoying buzz, and none of the digital audio fed to it. Power cycling it can help, I've made the following observations:
  • Power cycling the AC adapter helps some of the time
  • Power cycling by removing the DC plug from the device and re-plugging it helps all of the time(s that I've tried)
My informed guess is that the power-up ramp of that power supply might not quite meet the expectations/peculiarities of this device (and apparently both the device and its power supply lack a suitable internal reset controller). This guess is corroborated by the fact that the power supply has a power indicator LED, that slowly fades out when it is turned off. Upon being turned off this way, the DAC will output a significant pop and turn itself off quite early in the down ramp.
How would I go about finding a simple/cheap/wall-plug-type power supply (12V, 1A) that would exhibit a clean power-on edge rather than a ramp? I'm in Germany, as far as AC power and available brands are concerned.
Or, alternatively, is there a simple circuit I could implement on the DC side to delay passing power to the device until after the ramp has passed, or similar.?
Thanks a lot for any and all pertinent suggestions!
Offline jonpaul
Re: Simple power supply or conditioning circuit for decisive power-on edge
« Reply #1 on: February 21, 2024, 12:59:51 am »
Hello your note shows one of the classic symptoms of IC initialize failuer, esp te random fails.
 NO off the shelf power supply will have a controlled turn on with fast edge.
Designer of ANY device is responsible for proper turn on/init/rest ckt IN ORIG DESIGN. with a standard power source!!
Either
1/ Device is defective, and needs replacement/repair
2/ Device was poorly designed and tested contact mfg for refund
bon chance
Jon
Jean-Paul  the Internet Dinosaur
Offline dobsonr741
« Reply #2 on: February 21, 2024, 03:22:45 am »
A ready made Li battery under voltage lockout board could do. A typical schematics is as https://www.circuits-diy.com/low-battery-voltage-cut-off-or-disconnect/,
You’ll find many sellers of the same circuit on EBay and Ali. The relay will give you a nice snap.
The following users thanked this post: jmbreuer
« Reply #3 on: February 21, 2024, 11:44:06 am »
Thanks a lot, exactly the answer I was hoping for!
I found a cheap ready-made board and will give it a try.
« Reply #4 on: February 21, 2024, 11:49:22 am »
Hi Jon,
thank you. I understand where you're coming from; it's still something I want/need to 'solve' myself.
The device is 15 years old (so no warranty or such), and the manufacturer mentions that it's only supposed to be run with its own, "included", dedicated power supply - which I take to understand, they're kinda aware of some issue there.
That said power supply I never got in the first place, because I live in a different power socket standard country from the manufacturer. The one I picked out those oodles of years ago worked OK most of the time, when my usage pattern was to rarely turn it off at all. That has changed now.
And I wouldn't want to return the DAC in the first place, because in the performance characteristics that matter to me it's a perfect fit and has been for a long time.
So long,
   Joe
