Author Topic: Simple Resetable buzzer/LED circuit  (Read 947 times)
Offline challie2Topic starter
« on: June 11, 2019, 04:49:18 pm »
Hi there I am trying too get into circuits, and I have a project I want to build.
What I am trying to achieve is make either a simple relay or simple IC/transistor circuit that has primary function of being an alarm in the form of a buzzer and LED that must be acknowledged and reset by a button press. it has too be a 12 Volt circuit and cheap.
How I want it too work as follows there are too rooms that I want too have a simple alert and acknowledgment circuit using a buzzer and an LED, In each room there is an operator who has too press a button, Button 1 in Room A starts the circuit. Button 2 in Room B acknowledges the buzzer and LED and resets the circuit. But button 2 cannot start the circuit likewise button 1 cannot reset the circuit. This is very similar to the disabled toilet alarm but it is not for that otherwise I would buy a kit for that.
12Volts and cheap.
I appreciate any help.
Have a nice day
Many Thanks
Jamie Newman
« Last Edit: June 11, 2019, 04:51:14 pm by challie2 »
Offline Zero999
  • 0999
Re: Simple Resetable buzzer/LED circuit
« Reply #1 on: June 11, 2019, 05:06:52 pm »
You need a latching relay circuit.
