Author Topic: Sinewave with adjustable amplitude?  (Read 1933 times)
Offline BiOzZTopic starter
« on: November 18, 2013, 11:02:47 pm »
Im working on a DDS project and im using it to make 2 DC biased square waves (one inverted one ... verted? XP) at an adjustable duty cycle and 2-15v output and im using a AD9850 module that has a sine wave output ... i have the square wave part finished and working BUT i dont want the sinewave part to go to waste
i know im probably asking for electronic voodoo here but is there a way to simply amplify the sinewave (thats 1.2v p-p DC biased) to have the amplitude adjustable WITHOUT using a complicated attenuator circuit with all sorts of relays and sizable stuff in a small size? im working from 1hz to 25mhz and i have some 250mhz opamps on hand i can use
if i cant i will simply throw in a class B amp with a fixed 5v out but i would like to use this!
My one regret in life is learning to speak English on the internet ...
Offline c4757p
  • adieu
Re: Sinewave with adjustable amplitude?
« Reply #1 on: November 18, 2013, 11:07:15 pm »
Analog multiplier/variable gain amplifier. Or just use a damn pot...
« Reply #2 on: November 18, 2013, 11:20:22 pm »
i may have skipped over the fact that i need the only adjustment to be the variable power supplies current voltage adding on a second pot for just the sine wave amplitude adjustments would be rather silly
