Hi there everyone. I've been working on a new design, which is an extremely small, single lipo powered headphone amplifier, which still produces reasonable sound quality. I will be running a boost and an inverting switch mode regulator, and then fed into a linear reg to clean up the rails.
I've been taking my time with component selection, and I have rounded up many of the necessary components already, I'm just stuck on the linear regulator at this point.
I found
this component, which fills the role of using discrete +/- regualtors, but in a single package. It's ideal for my design, in every regard, except for the package. I have no problem with tiny smd stuff, msop and similar is fine, but bottom-mounted thermal pads are a real pain, and go against the design I've been aiming towards thus far - nothing too special needed to assemble the board ie. reflow gear. I'm very keen to avoid having an extra IC if possible, as I'm already squeezed for space, and want to keep wasted power as low as practically possible.
I was hoping that someone would be able to point me towards an alternative to the LT3032, in a easier to deal with package. A combined positive/negative linear reg seems like a hugely useful component, and something that would be used a fair bit in modern integrated designs, but I've had no luck finding any other similar components. If someone could enlighten me what, and where I should get it, it'd be much appreciated, as I can finally get to making this design into reality. If there's really no other easy option, I'd love to hear some suggestions for inexpensive, available, SMD parts, with low power, low quiescent current, and both positive and negative regulators (in a matched pair, like the 79xx and 78xx). It's been very hard finding a pair like this with the search tools on RS or component manufacturers sites. (my normal supplier is RS, so bonus points if they're available there)
Thanks in advance for any help.
Chris
