Author Topic: Reliability of Connectors Under Overload Conditions  (Read 1234 times)
Offline German_EETopic starter
« on: August 05, 2016, 10:15:05 pm »
Those of you interested in the electrical side of things may find the following video of interest:
Warren Buffett
Offline Monkeh
Re: Reliability of Connectors Under Overload Conditions
« Reply #1 on: August 05, 2016, 10:35:19 pm »
Shame the wire failed early.
Offline CatalinaWOW
« Reply #2 on: August 06, 2016, 02:40:36 am »
Seems that all of these connectors can handle anything that is safe to put through the wires.  Once the insulation on the wire is failing you are far past the point of any rational usage.
