This may be basic analog that I learned in school, but can't quite remember the correct answer.
Say one requires a 1kOhm resistor in op-amp feedback path, is it lower noise to just use a 1kOhm resistor, or instead to use some parallel combination of resistors to get to 1kOhm (2x 2kOhm, 3x 3kOhm, etc.)?
