Dirt Cheap huh. Care to point one out? It might be useful for testing the prototypes.
I'm building a series of induction chargers based on the Qi standard as a project for university. I've got two designs one with a single coil and one with 4 arrays of 3 coils. One array of 3 coils draws 3.2A and needs to supply AC through a half bridge inverter, which was the topic of another thread. The spec says I should be able to do +/-0.25V, but seems to indicate that it works mostly at 12 or 20V. I don't think it's a requirement to get very close to 0V.
The design in the above post looks like it could work well. The parts are specced from 1.22V to 25V, and simulations suggest I can get good accuracy with the opamp controlling the DC power supply.
On the quad coil array device , I was going to use 4 of the above design with a quad opamp(LM324), 4 DACs and a microcontroller. This design setup seems a bit obtuse, not to mention somewhat expensive. I haven't figured out a nice way to get the AC wall power to the device itself. I was thinking about using a transformer/rectifier setup, which would make the device bulky but be relatively simple for me to implement. Most of the power supplies(for laptops) I've found can't really provide the power I seek(20V*13A = 240W). could probably compromise here, as I've found several laptop chargers that can supply 180W. More realistically the device will probably draw closer to 30W-75W, as a couple tablets and a phone or a lithium ion charger operate in this range.
The single coil device is quite a bit simpler. One power supply, one DAC, one coil. Likely to draw <3.2A, I decided to just reuse the above supply to make my life easier and give me some headroom in the device itself. I was thinking about adding a 5V->30V boost converter, or replacing the design in the thread, so that this one has the potential to be powered over a USB connection and by common phone/tablet wall warts with a microUSB connection. This one could have uses in industrial design and hobbyist projects, allowing hobbyist integration of inductive charging into robots, wearables, and things more easily. The major downside to this one is that the coil's have to be aligned in with magnets, which can be a pain. It'll be a lot smaller and sleeker though.
