Author Topic: Small, Cheap AC Panel meters - Review and teardown  (Read 1312 times)
Offline intabitsTopic starter
« on: December 07, 2019, 11:55:04 am »
I did a quick and dirty review and teardown of these cheap digital AC panel meters that read voltage and current.
I got a blue one and a green one:-
The insides (I can't see any markings on the main chip):-
Pros:-
Bright clear display
Cheap (abut US$3.60)
Easy to mount
Can sense up to 100A (and up to 500V)
Cons:-
Doesn't show currents less than about 750mA
Current readings seem to be be low/inaccurate
Voltage readings are also a little hit and miss, only accurate to within about 2-3%.
For low currents they are probably pretty useless, but if the load is always over 1 amp, they may have a place.
I'm thinking that it may be possible to add a trimpot to  calibrate the current measurement. (But I need to get something to accurately compare it against)
Video:-
Offline magic
Re: Small, Cheap AC Panel meters - Review and teardown
« Reply #1 on: December 07, 2019, 03:10:55 pm »
Is this for mains?
How much overvoltage before  :-BROKE
;D
« Reply #2 on: December 07, 2019, 08:08:34 pm »
Yes, it is for mains.
The box says: 50V to 500V, and 0-100A
(meter seems to need a minimum of about 20V to operate)
Offline SiliconWizard
« Reply #3 on: December 07, 2019, 08:44:56 pm »
How is the current sensing achieved?
« Reply #4 on: December 07, 2019, 09:06:47 pm »
The unit comes with a current transformer, that connects via a 2 pin inline connector to a flying lead coming out of the back of the device.
The mains is connected via 2 screw terminals on the body of the unit.
I should have included a pic showing all this:-
