Author Topic: Small FPGA recommendation  (Read 10963 times)
Offline asmi
Re: Small FPGA recommendation
« Reply #25 on: October 28, 2017, 01:32:21 pm »
Icecube2 is anything but. You get a way to select the chip, I/O standards and pinout, but that's about it. Under the hood it's running Synplify Pro, but you don't have to touch it.
It gives you a choice of either using Synplify, or Lattice's own sythesizer.
The obvious omission - unless I've just not found it yet - is something equivalent to the Mega Wizard configuration tool for any built-in hardware blocks. Instantiating memory, for example, looks as though it requires either some specific, carefully crafted VHDL to be generated by hand and pasted into the source code, or alternatively, writing an accurate functional description of the behaviour of a memory block and hoping the synthesizer chooses to infer one.
There are wizards to instantiate PLL and hardened SPI/I2C blocks for devices that have them. Also there is SBT_ICE_Technology_Library.pdf file in Icecube's "doc" folder which lists and describes all built-in primitives, but FIFO is not listed there as it's not natively supported (you've got to use some LCB resources to construct FIFO from sysMEM blocks).
Offline Mr. Scram
  • Display aficionado
« Reply #28 on: October 28, 2017, 04:16:19 pm »
You mean "fake Max II", right? Because genuine ones with comparable logic resources to ice40 will be more expensive.
As a seller I bought an Altera device from said: "Who would fake these?"
Apparently Chinese do, considering my unit came with a Cyclone II model number and Cyclone III logo ;D It works perfectly fine as the Cyclone II denoted, and I actually bought it as such, so it's all good. It's not going into anything relevant anyway.
Offline asmi
« Reply #29 on: October 28, 2017, 09:24:20 pm »
Maybe they do work, but I prefer not to use illegal copies if I can help it.
Offline Mr. Scram
« Reply #30 on: October 28, 2017, 09:56:34 pm »
I do too.
Offline ebclr
« Reply #31 on: October 29, 2017, 02:05:57 am »
Again those "fake" fools, :-DD   Pay more for the supposed to be "original" and lets us play with the supposed to be fake, perfect working, perfectly reliable.
It's amazing but history is made a huge change, the US  is now the Police state, with regulations even to "drop a pun", more lawyers than engineers, while China is the real capitalism and freedom, there everything is doable, fakes reals, high quality, low quality, no restrictions of any kind,  no control off nothing just pure Market law and freedom.
« Last Edit: October 29, 2017, 02:50:46 am by ebclr »
Offline jmelson
« Reply #32 on: October 29, 2017, 02:38:19 am »
Hi all,
I have a design which requires a small FPGA, and I'm struggling to find an appropriate device.
Since nobody else mentioned this, there is also the Xilinx XC9500XL series, based on CPLD technology.  You can get the XC9536XL in the 44-pin package for $1.54 in single quantity.  This sounds like it might be too small for your application, they have larger devices.  These have 36-input gates, so the way things map out is quite different from the finer-grained FPGA LUT architecture.  Where comparing larger numbers of bits is required (like address decoders) they are great.
Xiling also has the Cool Runner II family, with an internal architecture more similar to FPGAs.  The XC2C family also are quite affordable in the smaller sizes, under $2.
Jon
The following users thanked this post: xzswq21
Offline asmi
« Reply #33 on: October 29, 2017, 11:28:45 pm »
Don't worry kido, just give it some time until you grow up and one day find yourself on the receiving end of all this. Will see what you will say at that time...
Offline james_s
« Reply #34 on: November 15, 2017, 08:51:52 pm »
Can't be a copy. The R&D cost for FPGAs is too high to make any profit. It's more likely to be a recycled part, the recycler removed the chip from board, and reprinted the markings to make it look like new.
Which is weird, because I'm perfectly content to buy recycled parts for hobby projects, I certainly trust them more than sketchy re-marked stuff!
