That's probably good for hobby / low volume / non-industrial but it ties you to a device which, if it goes out of production, lands you with a massive job. Whereas all the time you are using these "dumb" LCDs, you should be able to find an alternative.
The real issue is likely to be TFT panel availability. Normally you are stuck with a given size, to fit your box.
BTW what happened to the low temp issue? In say aviation one sometimes had a heater on the back of it. Hence OLEDs but they have a crap life. Wide temp range products tended to use vacuum fluorescent displays, which have lots of reliability issues too.
