Author Topic: Smallest rechargeable battery >= 10 mAh  (Read 4759 times)
Offline SiliconWizardTopic starter
« on: October 16, 2024, 11:42:52 am »
What is, to your knowledge, currently the smallest rechargeable battery (any chemistry) with a capacity of approximately 10 to 20 mAh?
Note: I had a nominal voltage of ~ 3V-3.7V in mind, so 30 mWh to about 60 mWh would be a better figure, regardless of the actual nominal voltage (preferably >= 2V though.)
« Last Edit: October 16, 2024, 12:04:08 pm by SiliconWizard »
Online tooki
Re: Smallest rechargeable battery >= 10 mAh
« Reply #1 on: October 16, 2024, 12:28:07 pm »
Panasonic makes a bunch of tiny rechargeable lithium batteries (various chemistries) in that ballpark, including their “pin type” cylindrical cells that are 3.6-4.7mm diameter, as well as a whole bevy of coil cells.
See the catalog here: https://energy.panasonic.com/dam/common/content/business/pdf/en/catalog/Catalog_EN_240701.pdf
The following users thanked this post: I wanted a rude username
« Reply #2 on: October 16, 2024, 05:37:10 pm »
I knew the pin type for primary batteries - often used for fishing lights, but not the Li-ion ones. Interesting, but I looked for a distributor and Mouser/Digikey came up. Apparently, they can't ship these references outside of the US. That bites. "Shipping restricted."
Offline Gribo
« Reply #3 on: October 16, 2024, 07:42:14 pm »
There are Li-Polymer pouches -
Example, I don't know this specific product:
https://www.eemb.com/product-120
Edit: They also have rechargeable coin cells.
I am available for freelance work.
Online langwadt
Offline thm_w
  • Non-expert
« Reply #5 on: October 16, 2024, 08:34:37 pm »
Searching on aliexpress could give you some ideas:
- VL2020 20mAh: https://www.aliexpress.com/item/1005007540618404.html
- LIR2025: https://www.aliexpress.com/item/1005007089618866.html
- airpod type batteries:
https://www.aliexpress.com/item/1005005426420820.html
https://www.aliexpress.com/item/1005003481586785.html
edit: langwadt beat me to the airpods, I think those they posted are better quality.
Online nali
« Reply #6 on: October 16, 2024, 08:42:00 pm »
Unfortunately a lot of Panasonic bettery products are for the OEM market, so you need a pretty high volume to get them interested (5 or even 6-digit quantities)  :(
The following users thanked this post: tooki, SiliconWizard
Online SteveThackery
  • 50 year novice
« Reply #7 on: October 16, 2024, 09:43:09 pm »
Some watches use rechargeable coin cells, in particular Casio, Seiko and Citizen.
There is a watch materials supplier in the UK called Cousins who stock a range.  For some reason they describe them as "capacitors", but I believe all the products are rechargeable batteries.  Perhaps you could find a suitable size and then check whether they really are batteries or capacitors.  Here are links to the pages on their site:
https://www.cousinsuk.com/product/citizen-capacitors
https://www.cousinsuk.com/product/seiko-capacitors
https://www.cousinsuk.com/product/special-capacitors-casio
Online tooki
« Reply #8 on: October 17, 2024, 06:27:04 am »
Yeah, lithium ion shipping is a problem.
But there must be some “native” European distributors that stock at least some of them.
Online tooki
« Reply #9 on: October 17, 2024, 06:28:11 am »
That is unfortunate. I guess it makes sense, but is annoying for the hobbyist or prototype builder!
Offline Someone
    • send complaints here
« Reply #10 on: October 17, 2024, 06:44:34 am »
But mysteriously they don't restrict the "hybrid" super capacitors. A 1/3 AAA size hits the OPs specifications. So about the same volumetric efficiency as a secondary *2032 cell.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #11 on: October 17, 2024, 08:20:55 am »
Might help to say more about  your size constraint - is it volume, thickness, max dimension?
Day Job: Mostly LEDs
Offline jwet
« Reply #12 on: October 17, 2024, 02:36:46 pm »
There was a hot company about ten years ago called Cymbet (Minneapolis) that made really tiny solid state batteries.  They got acquired or went bust but you can still find stuff online.  Most of their stuff was very, very small but they did do some larger.  In Chip Scale SMT packages similar to the TDK stuff from another poster.
Offline tom66
« Reply #13 on: October 17, 2024, 03:07:58 pm »
Seiko Instruments make some of these.  I've used the MS621FE in the past.
https://www.sii.co.jp/en/me/datasheets/micro-battery/ms-rechargeable/ms920se/
https://www.sii.co.jp/en/me/datasheets/micro-battery/ms-rechargeable/ms621fe/
One thing to be aware of is their cycle life isn't great if you use 100% DoD.  It's around 80-100 cycles.  To get maximum longevity from them don't go below 50% DoD regularly.
« Reply #14 on: October 17, 2024, 04:04:27 pm »
not where you buy for something serious but shows they exist
https://www.aliexpress.com/item/1005005043931275.html
https://www.aliexpress.com/i/1005006075527607.html
https://www.ebay.co.uk/itm/276385021878
Ah the 45230 for airpods could be an alternative to the panasonic pin batteries. Not sure what the manufacturer is. I can find similar ones in large quantities on Alibaba, the vendor seems to be Eunicell.
« Reply #15 on: October 17, 2024, 04:18:50 pm »
So far, the company I've found that seems to have the most choice with very small batteries is Coincell Battery: https://www.coincell.cn/
Offline RoGeorge
« Reply #16 on: October 17, 2024, 10:38:37 pm »
The smalles Li-Ion I have with protection board included is about the size of a nail in area, and about 5mm thick, but I can not find right now to give the exact size/part number/mAh.
Could be a 501017 or so
https://topwayenergy.en.made-in-china.com/product/xdzECiJGJukX/China-Small-Rechargeable-Lithium-Ion-Polymer-3-7V-60mAh-501017-Lipo-Battery-for-MP3.html
« Last Edit: October 17, 2024, 10:41:51 pm by RoGeorge »
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #17 on: October 19, 2024, 07:06:06 pm »
The CTL1616 has the familiar CR1616 form factor, but rechargeable (2.3 V nominal, 18 mAh). Used in high-end Casio watches with solar charging tech. Probably too expensive for consumer stuff though ... hard to beat a pouch cell with no protection IC (you can put the IC on your PCB instead, more space-efficient that way).
Offline YTusername
    • Atadiat
« Reply #18 on: October 30, 2024, 10:16:31 am »
Check Everpower manufacture for small batteries. My past employer have used a small capacity one, 8-9mAh, but I can not share the part number.
http://www.htkjbattery.com/en/products/customized-shaped-battery/68.html
You can check as well the 21mAh battery used inside ORAA smart ring which is exposed here (https://youtu.be/BwA1hmSVgVY?si=eA35yvRZ4wjhfWtN&t=470) GREPOWER YE160728 from https://www.grepow.com/.
