Author Topic: IR remote decoding in hardware?  (Read 4769 times)
Offline shadewindTopic starter
« on: September 02, 2012, 08:18:51 pm »
I plan on using an IR remote for a project but most guides to this seems to use bit banging for decoding the IR signal. This uses a lot of processing time so I'm wondering if there is a better way to do it than simply polling the GPIO?
Offline codeboy2k
Re: IR remote decoding in hardware?
« Reply #1 on: September 02, 2012, 08:35:06 pm »
sure. Do it on a small CPLD.  you'll need to write the verilog or VHDL code for it, which is not that hard to do if you're already familiar with using HDLs and programmable logic devices.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: September 02, 2012, 08:41:09 pm »
It needn't take much time - use a capture timer peripheral to measure the interval between edges - this will have fairly minimal processing requirements as data rate is typically only a kbit or two per sec.
Day Job: Mostly LEDs
« Reply #3 on: September 02, 2012, 09:56:55 pm »
A CPLD sounds a bit overkill and I was already thinking about the exact idea Mike is describing.
Offline eliocor
    • rhodiatoce
« Reply #4 on: September 02, 2012, 10:31:24 pm »
I suggest you to use the following Arduino library:
http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html
I ported it to different microcontrollers without too much fuss: it require very few CPU resources (except for the usage of an HW timer)
« Reply #5 on: September 03, 2012, 01:33:02 am »
That uses a repeating timer interrupt. Input capture would probably use less resources since the are no interrupts when nothing is being received.
Offline eliocor
    • rhodiatoce
« Reply #6 on: September 03, 2012, 01:44:29 am »
You are right: I modified the code exactly as you wrote (Freescale MC9S08AW60), but even working as in the original code, the burden on the CPU is much lower than what proposed by the original poster.
Offline firewalker
  • Country: gr
« Reply #7 on: September 03, 2012, 07:55:17 am »
Once I used the following library.
http://www.mikrocontroller.net/articles/IRMP
Alexander.
« Reply #8 on: September 03, 2012, 08:04:14 am »
The other thing about capture is it is insensitive to any latency caused by other interrupts, as the counter value is latched in hardware, so you only need to handle it any time before the next edge.
Offline amyk
« Reply #9 on: September 03, 2012, 08:18:17 am »
If you know the protocol that the remote uses (and there aren't that many) then there are ICs available that will do all the decoding for you.
E.g.
http://www.rentron.com/Files/CIP-8.pdf
Holtek also makes a few.
Offline ptricks
« Reply #10 on: September 03, 2012, 01:21:24 pm »
Most of the for sale decoder IC are simply standard off the shelf MCU that are programmed for that task. You don't need anything expensive, something like the $1 pic18F14k22 can do IR decoding for your main application MCU and that pic needs no external parts to work.
Offline codeboy2k
« Reply #11 on: September 03, 2012, 09:57:19 pm »
I read your post and thought you didn't even want the micro involved, so I proposed an off chip solution.
Often my first go-to solution is a hardware one, not a software one.
Mike's solution and other solutions using PIC chips to decode the IR stream are good for this too.
