Author Topic: Motor and Motor Controller  (Read 3198 times)
Offline aalaviTopic starter
« on: September 04, 2012, 12:49:54 am »
Hello all,
I received two motors and a driver (looks like a PLC i guess) for almost free from an old Ex-Nortel employee who needed to clean up his basement to rent out. I was hoping to receive some ideas as to  what you would do with them and how u would utilize them for a hobby/home project. Here are the parts:
Oriental Motor M540-201 (Speed Control Motor)
Permanent Magnet Servo Motor (R505-1621)
Super Vexta U1215GA Intelligent Driver
I have no document / manual for either :(. Any ideas or helps would be much appreciated.
These are some photos of parts
http://img826.imageshack.us/img826/7082/20120903200602.jpg
http://img152.imageshack.us/img152/479/20120903200644.jpg
http://img6.imageshack.us/img6/7669/20120903200816.jpg
http://img208.imageshack.us/img208/1436/20120903200858.jpg
Cheers,
AA
Offline amyk
Re: Motor and Motor Controller
« Reply #1 on: September 04, 2012, 08:26:51 am »
Not sure about the second one, but I think the first motor is intended to be used with the speed controller for a variable-speed drive.
Here's their product page:
http://www.orientalmotor.com.sg/products/sc/
Offline Rerouter
« Reply #2 on: September 04, 2012, 08:57:27 am »
http://stevenengineering.com/Tech_Support/ORIENTAL_MOTOR.htm
there you go :)
edit: just hope its not a chopper type variable speed controller, those things inject crud loads of noise back down your ac mains,
« Last Edit: September 04, 2012, 08:59:20 am by Rerouter »
« Reply #3 on: September 04, 2012, 03:45:56 pm »
Thanks guys! I will go through the two recommended sites to see if I can get an idea of how to work with these motors.
If I may, how would you get started with utilizing this motor? The 1st motor has 6 wires. I think 1st two are AC 110V to mains, the other 4 are control wires. Would u use an off the shelf motor driver or would u make ur own driver for it?
Thanks a bunch!
Offline G7PSK
  • It is hot until proved not.
« Reply #4 on: September 04, 2012, 05:30:04 pm »
Sell them on ebay, a wind power fanatic will snap them up.
« Reply #5 on: September 04, 2012, 06:22:33 pm »
I could probably count "sell on e-Bay" as a "use" for these parts  :). Thanks for the comment though.
I am really interested in learning how to use motors in general. I just hope i can get a hint on how to get started with these two parts.
Thank you,
AA
