Author Topic: Detecting bi-polar input using Arduino / MCU  (Read 899 times)
Offline danners430Topic starter
  • Good at overcomplication
« on: July 12, 2018, 03:15:38 pm »
Afternoon folks,
Yet another question regarding RC receivers, albeit loosely :-)
I've discovered that the RC receiver I'm using outputs a bipolar PWM signal depending on user input. If the joystick is moved "forwards", we get a positive voltage, and if it's moved "backwards" we get a negative voltage.
Since Arduinos and MCUs generally can't detect negative voltages, I thought of using a pair of optocouplers to detect the two signals - one for detecting the positive voltage, the other to detect the negative voltage. Does this sound like a reasonable solution?
Cheers
Daniel
Offline In Vacuo Veritas
  • I like vacuum tubes. Electrons exist, holes don't.
Re: Detecting bi-polar input using Arduino / MCU
« Reply #1 on: July 12, 2018, 03:41:50 pm »
What receiver is this? This isn't like any RC radio I've ever heard of.
Why not just couple the signal to 1/2 the rail with a resistive network?
Offline Zero999
  • 0999
« Reply #2 on: July 13, 2018, 07:43:33 am »
What voltages do you expect from the negative PWM signal?
How about scaling the voltage to within the power supply rails of the MCU and using a comparator to detect the appropriate threshold voltage?
Offline mikerj
« Reply #3 on: July 13, 2018, 07:44:48 am »
Sounds like this receiver has a motor speed controller built in and the OP is looking at the voltage across the two outputs.  If so them measuring each output with respect to ground should give a unipolar PWM signal.
« Reply #4 on: July 13, 2018, 07:46:18 am »
Hey guys,
Sorry for the lack of response, I was about as busy as could get yesterday [emoji23]
I've double checked with the manufacturer, and the info I was getting is wrong - it actually outputs a positive PWM signal, no negative voltages used... Problem solved by itself!
Cheers anyway folks!
Sent from my ONEPLUS A3003 using Tapatalk
