Author Topic: Is there any specs other than the operating temperature for automotive LCD dplay  (Read 574 times)
Offline muthukural001Topic starter
  • Country: in
Hi All,
I am looking for an automotive-grade LCD display. I see the many displays claims that they are automotive-grade with the operating temperature -30 to +85 C. At the same time, displays that have the same operating temperature  -30 to +85C tells that they are not an automotive-grade. From this, I can understand that the operating temperature is not the only parameter to decide whether it is automotive or industrial grade. So, what other parameters that I have to look for the automotive LCD TFT display?
Thanks,
Muthu
