Probably 50'.
That´s like 15m, right?
In that case there should be no problem at all. I have a huge 1-wire bus running through the entire house, with around 30 DS18B20s and some other devices connected to it and I think more than 100m of cables (CAT7). They run all over the place, there are many dead ends etc.
One easy thing you could do is add some 100nF capacitors next to all/some of the devices from +5V to GND. That should keep the supply voltage for the 1-wire device more stable. However in my case, there isn´t a single one of those installed in the entire system.
