Two and a half months later we finally have a transformer
The major holdup was the TIW, one lot arrived and seemed fine until actually in the wind I discovered an unexpectedly small number of turns per layer and on close inspection discovered the insulation was 0.125mm thick instead of 0.1mm
The cores were a good laugh too, I had to wait for three shipments altogether with much supplier discussion as they kept arriving smashed
So another zzzzzzzzzz time later with the correct TIW winding began again, a layer of tape over the 1st primary layer helped to protect it from the heavy secondary wind. 2 layers of tape were required over this to prevent the next secondary layer dropping between the primary turns.
The build-up is a little weird as although the primary is a single layer both secondaries are a layer and a half each (sods law in action)
So layer 1 is S1, layer 2 is primary, 3 is S2 and 4 is the remaining halves of both S1 & S2. Resulting leakage 450nH.
This is an ETD59, gone up a core size as it was to tight on an ETD54. The two secondaries work very happily in parallel that if anybody can remember was the original question
I also chose to use flying lead terminations as this is a chassis mount transformer rather then pcb and the primary is to big for the little bobbin pins anyway.
Ohh I should mention I sweated the slot (pin) numbers carefully to ensure the two secondaries anded up with exactly the same number of fractional turns.
Lot's of pictures ...........
