Author Topic: SMPS replacement for audio power amp transformer  (Read 2644 times)
Offline BlackICETopic starter
« on: December 28, 2019, 08:59:24 am »
I have a old Hafler DH-220 I'm haven't used for decades and thinking of bringing back to life. I have read about the aging of electrolytic caps and it wouldn't be too hard or expensive to replace them all with the exception of the large filter caps on the power supply. They are 10K uf at 75V.
That got me thinking about what if I replaced the large heavy CT transformer that is about +-44V RMS at 4 amps with two 48V 5+A SMPS. The box would be lighter, more energy and efficient and I could choose the SMPS current output and size the "filter" caps depending on the peak current I wanted. I would bet with a higher current SMPS the amp could output much more than it's spec. 110w per channel for a few seconds before any thermal overloaded would occur. My main concern would be the noise of the SMPS causing havoc and showing up at the speaker output stage degrading the sound quality.
Any opinions are welcomed.
An example of a cheap (bad/dangerous?) off the shelf SMPS. It probably cost less than a new filter cap.
https://www.ebay.com/itm/48V-4A-5A-200W-AC-DC-Power-Supply-Converter-Adapter-SMPS-Board-Voltage-Transform/264468367469?hash=item3d938b086d:g:oP4AAOSwpLpdgHja
« Last Edit: December 28, 2019, 09:07:24 am by BlackICE »
Offline German_EE
Re: SMPS replacement for audio power amp transformer
« Reply #1 on: December 28, 2019, 10:06:37 am »
There are two problems with your plan.
Firstly, as you pointed out, switched mode supplies are noisy. Even with decoupling capacitors spread around like candies you will still hear background interference and any hum loops will increase this problem.
Secondly, your amplifier transient response will suffer. 10,000 uf @ 75V is a lot of capacitance to lose and this will show in the response of your output stages.
Please do not do this, audio power amps need big transformers and big capacitors.
Warren Buffett
« Reply #2 on: December 28, 2019, 11:17:20 am »
I wouldn't necessarily omit the filter caps. I could even use larger ones. Then by using a higher current SMPS the amp would have the same or better transient response as well as better intermediate response. However as we both said the noise issue still persist. Maybe shielding the PS and locating it remotely would mitigate the noise issues but that would be a packaging issue and little real use gain in my case, but the specs may look better.
Offline MagicSmoker
« Reply #3 on: December 28, 2019, 12:47:41 pm »
Meh, the claim that SMPSes produce too much noise to be used in audio is overblown, IMO. Sure ripple and noise from a hard-switched SMPS are going to be worse than the typical linear power supply, but given that the switching frequency will invariably be well above 20kHz it won't be audible even if PSRR of the amplifier has dropped to 0 by then.
The real problem with SMPSes in this application is the potential for interaction between two control loops - the voltage regulation loop in the switcher and the negative feedback loop in the amplifier. Pretty much every car audio amplifier sidesteps this problem by running the switcher open-loop, and that's not a bad solution, really; I would suggest always using pulse-by-pulse current limiting, however.
Offline David Hess
  • DavidH
« Reply #4 on: December 29, 2019, 11:17:21 am »
The power supply is sized for the average output current so additional output capacitance is likely necessary to handle the surge current.
The bulk output filtering capacitor damps any interaction.
The reason the switcher is run open-loop is that it is not a switching regulator.  The power amplifier does not require a regulated supply so instead an inverter is used to multiply the automotive DC voltage to a higher level allowing more power into the load presented by the loudspeaker.  (1) Since an inverter is used instead of a switching regulator, a large energy storage inductor is not required and with a transformer inverter, ripple current at the input and output are low relaxing the requirements for the input and output capacitors.
(1) This is also why 4 and 2 ohm speakers are commonly used in automotive applications instead of 8 ohm speakers.
Online Kleinstein
« Reply #5 on: December 29, 2019, 12:41:45 pm »
The transformer only needs to be sized for average (sine) power. A transformer can deliver higher power for several minutes with no problem.
An SMPS would need to deliver the peak current - extra capacitors at the output would not help much as the voltage is regulated.
So for 110 W output power and 8 Ohms load the peak current would be at around 6 A with sine, maybe 8  A for peaks in the music.
So the SMPS would be sized more like 12-16 A to power 2 channels to get the same power level as the old transformer.
The tendency would be to get higher sine power but less music power rating.
So just for the filter caps it is probably not worth to replace the transformer. One may get away with slightly smaller caps with no so much loss in power.
P.s. The 44 V AC would give some 55-60 V DC at the filter cap. So the SMPS would need to be more like 55-60 V too. 48 V DC would give less power as the voltage would be lower.
« Last Edit: December 29, 2019, 12:44:39 pm by Kleinstein »
Offline NiHaoMike
    • Facebook Page
« Reply #6 on: December 29, 2019, 01:04:24 pm »
Most likely the big caps will be just fine and "reform" them to be sure.
Offline diyaudio
« Reply #7 on: December 29, 2019, 07:23:46 pm »
SMPS for audio is fine, so is a ( heavy, 50/60hz humie transformer), all car amplifiers uses an SMPS for power conversion (no issue with the cheapest Chinese power supplies). Hypex a lead manufacturer of Class-D amplifiers are using SMPS for their audio products example see NCORE, The only reason why people claim by default all of them are noisy!? for audio is when designed really badly (and its hard to do this with current technology even the cheapest shit looks sounds good) even modern sub-woofers applications for home audio are "switching" over to SMPS, some die-hard audio/primitive thinkers may find this hard to ingest, another point the PSRR (power supply ripple rejection) from the +5/12/15 voltage regulators are so high.. its only possible to see this so called noise with a scope and never even hear it because the rejection ratio is in the 90dB range!!
Iv'e seen some high-end equipment and pro-audio using SMPS in the numbers (and this number is only growing today)
The lame dog response "add more capacitors line" and she will be okay.
Lame, music material doesn't have constant sustained power (look into voltage rail sagging), crest factor is used to determine power, adding more capacitors is a fools paradise (and doesn't solve the problem as the more reservoir caps are added to an already optimized reservoir bank will only lead to longer charge cycles during  high demands and when fully drained will definitely cause a surge on the primary during turn-on, blowing the mains fuse)
« Last Edit: December 29, 2019, 07:34:12 pm by diyaudio »
