I found a "cheap" 2004 5CD stereo in the garbage, fuses are good, probably worked. So thats great, now I have a 100W transformer of the size I want for breadbroading on my desk.
So far I have taken it apart and set aside the 100W transformer (no center tap tho
) and its main PCB which is just pretty basic and I think only analog on that board. And the PCB is wide open with lots of unused places, which is great because I can reuse the board and mod onto it some LM723s and what not that I bought for making my own stuff. So I'll make an adj voltage and adjustable current supply. And also make another separate split rail supply that I can switch over too. And I can put it all back in the bottom/back of the plastic case and add a wooden cover, dials, switches, etc.
Also there was an audio output filter board the size of a chocolate bar (2cm*3cm*7cm). It has L/R RCA plugs and the spring loaded speaker outputs. It also has a 8pin ribbon cable. So I took all the LCR stuff off the PCB and soldered up a basic LM317 adj. voltage regulator with an LED so far. I have some nicely secured alligator clips on there as well and a switch. I have to find my little drills and add in some current regulation and opamps too for fun. Blinky LEDs too like on STAR TREK. I didn't map it all out for using the traces for the next steps, but thats fine. I'll dead bug it and wire it with more switches. And I'll put it in a remote control case. For now I'll just use that with a 24V laptop PSU I guess, and stop using the 12V modem PSU. Add its a nice little compacted thing that will further reduce the wire clutter I hope
I have the radio section PCB, a TOSHIBA TA8258H 80W 4ch mixer audio amp, all the motor stuff. And how hard is it do re-purpose the non-LCD display with wires inside, can't remember name. I don't know/remember much digital or programing. But even just lighting up any part is fine so long as u control it and then it can represent whatever u want.
Most of the chips in the stereo I can't find anything on. Look forward to seeing what all that stuff looks like on a scope. Probably not like much, but the radio and motor PCBs I'll power up and see.
