You won't get the results you want from anything in a spray can. That kind of application requires very low viscosity, so the material is going to have an unavoidable tendency to pull away from sharp edges. What you need for that effect is a thick, fast curing material, such as UV cured, applied by curtain coat or something similar.
You might try hanging the board upside down during and/or after coating it, but it may not help that much.
