Author Topic: Strange layout of current sense IC  (Read 490 times)
Offline eTobeyTopic starter
    • Virtual feature script
« on: March 09, 2023, 04:05:20 pm »
i am not a professional, but i found something that looks strange to me. Its from a yamaha ebike motor (PW-ST).
Its a current sensor of a phase of the brushless motor.
The fuse is rated for 30A, but these traces, even if they are short, look quite stupid to me. Also the manufacturer does suggest both pads to be on a plane.
Anyone know of a reason for this strange layout?
Cheers
Toby
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
Offline coromonadalix
Re: Strange layout of current sense IC
« Reply #1 on: March 09, 2023, 05:05:26 pm »
must be an hall effect current sensor
and please don't start threads about the same things / double threads  ...
you ask about a ic
https://www.eevblog.com/forum/projects/current-sensor-mpq8113-any-good/
and you se in the pdf   the working principles / applications
« Last Edit: March 09, 2023, 05:08:47 pm by coromonadalix »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: March 09, 2023, 07:30:49 pm »
What traces?
You mean the pads?  Those are covered in solder and component leads.  And are very short.  Copper is an excellent conductor, you can pinch down quite a bit and stay within thermal limits as long as the heat has somewhere to go.  Traces only reach steady state limits over long lengths (some inches).
I would pour copper over/around the pads personally, but this here is far from a disaster. :-+
Seven Transistor Labs, LLC
