Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
SN74LVC1G19 1 bit inverter?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: SN74LVC1G19 1 bit inverter? (Read 621 times)
NivagSwerdna
Super Contributor
Country:
on:
June 19, 2020, 04:14:09 pm »
For a circuit I am looking at I need a nCS and I have a signal which is CS... so basically I need a 1 bit inverter and I need it small and cheap and efficient etc...
I came across SN74LVC1G19 which seems a bit weird but might work... for me nE would always be LO
Would that be a sensible choice?
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: SN74LVC1G19 1 bit inverter?
Reply #1 on:
June 19, 2020, 04:21:59 pm »
A mux..?
Recommend avoiding LVC unless you need the speed or some special features. HC is abundant, and you're looking for the '04 or '14. So, *74HC1G14.
If you don't need speed, and a little current consumption is acceptable, also consider a pull-up resistor and a switching transistor, MMBT3904 (also with base resistor) or 2N7002 for example.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
NivagSwerdna
Super Contributor
Country:
Reply #2 on:
June 19, 2020, 06:55:27 pm »
74HC1G14GW looks perfect!
Logged
Benta
Super Contributor
Country:
Reply #3 on:
June 19, 2020, 07:14:43 pm »
There are a plethora of single-gate logic (aka kludge logic) families available from several suppliers. CMOS 4K, HC, AC, LVC etc. Just find the one that matches the rest of your circuit.
Logged
NivagSwerdna
schmitt trigger
Super Contributor
Country:
Reply #4 on:
June 19, 2020, 07:50:43 pm »
One-gate logic is the greatest invention since sliced cheese.
It has saved more than one engineer, myself included, to kludge a gate with diodes, resistors and transistors. What is euphemistically known as Mickey Mouse Logic.
http://musicfromouterspace.com/analogsynth_new/ELECTRONICS/mickeymouselogic.html
And with packages sizes ranging from SOT23 and smaller, total board real state is similar to a single discrete transistor.
Logged
NivagSwerdna
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
