Author Topic: Snake! on my TTL breadboard CPU (Hackaday article)  (Read 826 times)
Offline visrealmTopic starter
  • Aussie software guy and electronics enthusiast
    • GitHub
« on: July 12, 2020, 03:45:11 am »
Pretty chuffed - it seems someone wrote a Hackaday article about Snake running on my breadboard CPU build... in April  ;D.  Seems I was a bit late to realise.
https://hackaday.com/2020/04/26/breadboard-computer-plays-snake-on-character-display-also-in-a-browser/
Cheers
Troy
« Last Edit: July 12, 2020, 04:37:07 am by visrealm »
Offline Kashif
    • Explore Silicon
Re: Snake! on my TTL breadboard CPU (Hackaday article)
« Reply #1 on: July 12, 2020, 03:56:16 am »
Wow looks very cool! just curious what is your CPU clock speed?
The following users thanked this post: visrealm
    • GitHub
« Reply #2 on: July 12, 2020, 04:10:33 am »
Thanks.
It's variable (using a 555), so I can get below 1Hz. I can also single-step it.
It currently goes up to around 20-25KHz at full tilt. It *might* be capable of faster, but I haven't tried ...and being on breadboards, probably wouldn't go much faster than that.
