Hi All,
I want to mount some small temperature sensors (transistor type in an enclosure). I want these sensors to be removable hence I plan to use a tiny connector. On the other side I would like to have a wired socket fixed in a plastic holder with wires already routed hence I can swap the sensor.
Does anyone know of any family which offer wired sockets (with crimps for easy assembly and avoid soldering) to PCB plugs? Ideally, I need only 1x2 with small pitch 1mm or 1.27mm
Thanks
