Author Topic: Fairchild 777 dualbeam scopen info  (Read 1763 times)
Offline PA4TIMTopic starter
« on: December 13, 2012, 02:24:46 pm »
I'm restoring a Dumont/Fairchild 777 4 plugin, dual beam 100 MHz scope from the late 60's.
I found manuals for some of the plugins but not for the psu / display unit ( or mainframe as you like)
It looks a bit like a solid state version of the Tek 556, it is allmost as big but then modtly silicium and nuvistors.
The PSU looks like the one in a 766 but this one has three adjustments the 766 does not have. -50, +50 and +100 balans. And I have no clue how to adjust them and their purpose.
Problems found now is a few totally dead filter caps ( electrode ripture) and as a result no stable -50V Vref and a huge ripple.
One vertical plugin is dead. No respons on vertical position, beamfinder or input but that should be rather easy to fixbecause i have the manual from that plugin.
Does anyone has info ?
Re: Fairchild 777 dualbeam scopen info
« Reply #1 on: December 19, 2012, 06:12:35 pm »
Is this scope realy so rare that no one knows it ?
