Thank you guys for so much valuable infos, I really appreciate it and you helped me really.
I would go back to the post #14 to the this video from YT :
https://youtu.be/HzSlUDdiTScI have two questions:
1. The owner of the video put two resistors in parallel R1 and R2, for what is this any good there?
I mean, one resistor is enough to limit the current for the LED.
2. In the video, he is talking about the "firing angle", ok, that is the triac G signal.
If I understand correctly how it is working:
Practically the half wave in 50Hz is 10ms long.
The G signal starts for the 10th ms and is counting backward and is triggering the G in this way:
1. trigger in 10th ms
2. trigger in 9th ms
3. trigger ins 8 ms ... etc. to 1st. ms
and the cycle is starting again.
If this is as I understand, how long could be the High time of triggering signal,
which is represented on the oscilloscope on "Chanel C" ?
Thank you.
