Hi All,
I have a WEIR 4000T Bench PSU, 30V 1A, 80s era electronics. It has a 2x ADD3701 DVM Chips (one for Voltage and the other for Current displays) and 2x DS75492 Digit Drivers each drives a 4 Digit Common Cathode 7 segment display.
The original fault with the PSU was dead segments, so i bought some modern 7 segment units, usual 0.56" height digits and wired it up the same. So that the DS75492 is switching the Cathodes of each Digit, while the ADD3701 is switching the anode to the +5V rail of each of the segments to be illuminated. There was an array of 68R resistors in series with each of the 7 segment anodes (between the ADD3701). As the display was very very bright (almost too bright), i bumped these up to 220R and they are now a good intensity, but overall the display now work just fine.
However Im not sure if its due to the change in 7 segment module, but now i am picking up the switching noise on the output of the PSU, typically in order of 20mV Pk to pk. The worst of it is when the digits get switched (approx 625Hz), although there is still ringing on the output when it is changing between which segment to be illuminated (approx 1.6-4kHz) which is typically 12mV Pk2Pk.
The PSU layout of the Display board isnt great, so the VCC line for the ADD3701 travels almost around 2/3 of the perimeter of the board before reaching the driver IC, but fitting additional decoupling caps at each IC (10nF || 100nF) directly on the underside and also fitting wire links to try to shorten the "loop" currents from the 75492 back to the ADD3701, hasnt really helped.
The PSU can be disassembled to an extent, as it is constructed with 2 PCB's with harnesses going between them, one for the Linear regulation, and the other for the Displays. Moving the Measurement/Display PCB away, does significantly reduce the switching noise as nothing is screened, i suspect it is just getting coupled across, however im at a loss as to what else to try without rewiring the entire unit with screened cable.
Am i chasing my tail trying to resolve this switching noise? I hoped that going to the 220R resistors from 68R would have significantly reduced the loop currents in the circuit, but it is still measurable on the output connections.
I have even gone to the extent of using some sticky back aluminium foil and covering the rear of the 7 segments as well as the wiring from the Display PCB which made little difference. But with it completely disassembled but still wired/connected together, an offcut sheet of 1.0mm Stainless Steel attenuated the ringing nearly completely from the output, so i dont believe it is conducted via the harness, but just radiated from the display PCB. But i would rather find ways to attenuate the noise at source, rather than blocking it elsewhere. I cannot measure the noise actually on the Linear Reg circuit, so i think its filtering is working correctly and i dont think that is amplifying it, but it is just noise coupled to the output.
Does anyone have any other suggestions to reducing the switching noise? Afterall, if i wanted a noisy PSU, i would have just used a Switch Mode unit instead
Thanks
