IMO, those are the go-to books on power amp design. They're different and emphasize different things. Both are essential if one is serious about this stuff, but obviously a lot of power amps were built before they were ever written. Some even worked! They don't spend much time on single supply designs, but there are lots of commercial examples to study. Almost all the lower power receivers used single supplies and capacitor coupled outputs back in the day. Once you start seeing current sinks and differential inputs, bipolar supplies become the rule. I'm guessing that if they were going to bother with higher performance circuitry, they'd also want to get rid of output coupling caps, so went with bipolar supplies. Obviously you don't have to, but it makes a certain amount of sense.
One more thought on the above circuit- you'll usually see power applied at the top right, to the outputs, with a resistor isolation the low level part of the circuitry, and a moderate filter cap to ground on the low level circuit side of the resistor. No matter how good the supply is, the output current will tend to modulate it. (I think this was mentioned in one of the posts above.)
