Author Topic: Software to print .eps files under Windows XP?  (Read 4037 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: November 28, 2013, 01:54:11 pm »
I very infrequently need to print .eps files to transparent media to create printed circuit boards. I last did it using an older version of Paint Shop Pro, but its trial expired. Whilst I know I am tight, buying it to use twice a year seems a bit excessive. Is there any free software to do this under Windows? Ghostscript (or is it Ghostview?) apparently does it, but I am told it's a nightmare to install and get working. Thanks.
Best regards,
                 Chris Wilson.
Offline Crazy Ape
Re: Software to print .eps files under Windows XP?
« Reply #1 on: November 28, 2013, 02:01:22 pm »
This says it will convert eps to other more common formats.
http://epsviewer.org
Offline Crazy Ape
« Reply #2 on: November 28, 2013, 02:09:44 pm »
I just clicked a .eps file in my file browser (on Linux) and it opened up in Evince, which has a print option.
You could try the Windows version of Evince:
https://wiki.gnome.org/Apps/Evince/Downloads
« Reply #3 on: November 28, 2013, 06:13:13 pm »
Evince doesn't print .eps under Windows, I asked on the support forum. BUT, I found a one version newer set of plug ins for irfanView and it's showing and printing .eps files in the correct size! Sorted, thanks all! I have used Irfan View for years, it seems it has only just gotten this sorted. Free as well, although I made a donation as it's so damned good. Cheers.
Best regards,
                 Chris Wilson.
Offline Stonent
« Reply #4 on: November 28, 2013, 07:11:13 pm »
I would think Paint.NET would do that.
Offline peter.mitchell
« Reply #5 on: November 28, 2013, 09:41:30 pm »
Adobe Illustrator does the job, i get the slight feeling it may be overkill for what you're looking for though...
« Reply #6 on: November 28, 2013, 10:47:48 pm »
Err, just a bit, yes :)
Best regards,
                 Chris Wilson.
« Reply #7 on: November 28, 2013, 10:48:49 pm »
Not heard of that, will Google, thanks.
Best regards,
                 Chris Wilson.
Offline Crazy Ape
« Reply #8 on: November 28, 2013, 11:15:00 pm »
A web based option.
http://www.go2convert.com
Offline nctnico
« Reply #9 on: November 28, 2013, 11:45:50 pm »
Perhaps GIMP (the free Photoshop) can do it.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: November 29, 2013, 05:37:08 am »
tried adobe (free) acrobat? my pro version open "simulated eps" just fine. open->file->all files (*.*)
Online amyk
« Reply #11 on: November 29, 2013, 12:06:00 pm »
Try InkScape, the free Illustrator. It's definitely support EPS.
