has anyone experiences with modification of these cheap sine DC-AC-inverters?
I have a 12V-->230V unit with rated 800W and 1600W peak power. I just want to power around 150W an average, so there should be enough margin.
I have a battery pack of 5 LiFePo-Cells in series. This delivers between 14V and 18V. If it´s not fully charged, the mentioned inverter receives less than 16V and is flawlessly working. The inverter uses a feedback voltage regulation, so I measure around 230V AC over all allowed input voltages.
If 16V are exceeded, the unit beeps and switches off due to overvoltage.
Here is the question: Is the 16V upper voltage limit negotiable? The caps in the circuit are rated for 25V, the FETs for 40V. Does anyone know if it´s possible to increase the voltage limit to 18V without further modifications?
Thanks in advance, best regards...
