You want to design and build a 500 VA mains transformer for 120 or 240 V ?
DES: The normal desing process is to choose a lamination, core size and stack according to the VA and mains freq, then to calculate turns ratio, and finally the wire sizes and # trurns based on bobbin winding area.
There is no spreadsheet that does this to my knowledge.
The software we used for decades was Intusoft Magnetics Designer,
http://www.intusoft.com/mag.htmOne of the best and easiest to use.
But sadly the creator passed away, but it is still available.
Fab:
How many do you need? Just one?
Are you familiar with safety, wire, bobbins, laminations, impregnation?
I do not reccomend DIY transformers for mains use.
Off the shelf transformers are readily avail, see Mouser/DK/RS/Farnell.
Jon
