Hi group,
Time to share another project with the group. This time it is a transient limiter designed to protect spectrum analyzer inputs from damage, especially when doing EMC tests. The design is based on the discontinued HP 11947A.
The device is a combination of:
9kHz High Pass Filter
10dB attenuator
Limiter than limits the output to 1.4V p-p (about 5mW)
LTspiceLike many of my projects I started with an LTspice model:
and the modeling results:
The modeling shows 10dB of attenuation a nice 9kHz filter with steep roll-off.
SchematicThe schematic was drawn in KICAD:
PCB DesignThe circuit is laid out using 50
coplanar waveguide. The board is designed to replace the lid on a Hammond 1590G diecast box.
Mechanical DesignI reviewed the mechanical design using Fusion 360:
Prototype BuildHere is a picture of the prototype board. The board was made on my LPKF c60.
And the assembled unit:
In the next message I will present the measured test results.
Regards,
Jay_Diddy_B
