Electronics => Projects, Designs, and Technical Stuff => Topic started by: Lucky-Luka on June 01, 2021, 09:06:46 am
Hi all
I have an RGB LED led that needs more or less 3 volts to perform correctly its light routine.
Can I use for my project a 3.3V zener diode?
Only using the rectifier diode and the cap as a buffer the voltage would be a rather constant 4.8V.
Cheers
There are constant current diodes, that do this. They pass 20mA or 40mA or whatever its setting. On semi makes them for example.
I think this is not a proper solution for my problem.
Just increase the capacitance and inductance. Try at least 470uF for the capacitor.
Are these any help:
https://youtu.be/FsA79XdV1wk
https://youtu.be/wHje7_suqE0
