Hi!
I want to use a component that has castellated mounting holes.
The component has 1.27mm pitch (0.01 inch) and each pad is 0.84 x 1.22 (including the semi-circle cut).
The design should be good for both hand soldering and for reflow soldering.
Are there any design guidelines for the solder pads dimensions (widgh, height,padding, etc)?
