Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Soldering DC charger to F-type connector cable
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Soldering DC charger to F-type connector cable (Read 854 times)
Uner
Newbie
Country:
on:
May 21, 2024, 05:42:59 am »
I want to solder a new charger like this:
So I think I need to buy 14V 1A+ AC/DC charger and solder it to F-type connector,
But I'm not sure where should I solder the GND to on the connector
And if I solder the DC charger to the wire itself which of the parts is the GND? (The Aluminum shield?)
Thanks.
Last Edit: May 21, 2024, 05:47:21 am by Uner
Logged
jpanhalt
Super Contributor
Country:
Re: Soldering DC charger to F-type connector cable
Reply #1 on:
May 21, 2024, 05:52:49 am »
Aluminum is not easy to solder and the central connector may be copper plated steel. You might be able to solder to a standard connector and the center conductor, then heat shrink over it.
Logged
jonpaul
Super Contributor
Country:
Analog, magnetics, Power, HV, Audio, Cinema
Reply #2 on:
May 21, 2024, 06:21:48 am »
find correct female F connector, wire to charger.
YOU CANT SOLDER TO THIS CABLE
Only crimp
j
Logged
The Internet Dinosaur..
passionate about analog electronics since 1950s
Uner
Newbie
Country:
Reply #3 on:
May 21, 2024, 08:11:20 am »
Thanks for your reply,
jpanhalt, What do you mean by a "standard connector"?
jonpaul, How do I know which is the "correct" female f connector?
Last Edit: May 21, 2024, 08:18:10 am by Uner
Logged
jonpaul
Super Contributor
Country:
Reply #4 on:
May 21, 2024, 08:27:51 am »
F Jack Panel Mount F-61 Connector Solder Type Chassis
very common see local electronic disty or Amazon, ebay etc.
j
Logged
jpanhalt
Super Contributor
Country:
Reply #5 on:
May 21, 2024, 10:14:26 am »
Quote from: Uner on May 21, 2024, 08:11:20 am
I meant a connector plated with a solderable metal, like nickel. I suspect that's common. Then, solder a wire to the connector and crimp that to your Type F coax shield.
A female connector, as shown by jonpaul, could be soldered to the leads from your power supply. Then use a gender changer to get the male Type F . They are about $6 at Amz.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
