Hi all
I'm finally getting a design underway and have selected some of the major components. However, there are a few peripheral parts which I need to select. Can anyone suggest common / jellybean choices for the following:
- An I2C port expander. I expect to have 2 of them on the same bus, so I'd like one with address select pin(s)
- A Digital to Analog Converter for DC level setting. I need something like 4 channels @ 12 bits, and all the options on DigiKey seem to be really expensive at the moment. I2C preferred, SPI would be OK.
- A clock multiplier to get from a crystal (say 10 MHz) to 180 MHz. I'm thinking the Si5351A...
Background: I want to build an Impedance Analyser to operate from 50 Hz to 10 MHz (and maybe above 10MHz in the future).
Current plan is to build an auto-balancing RF bridge. Drive voltage (Force +) and balance current (Force -) sine waves will be generated by two channels of an AD9106 quad Direct Digital Synthesis (DDS) chip and appropriate analog circuitry.
The remaining two channels of the AD9106 generate a quadrature LO which is then used to demodulate the measurement signals back down to I and Q signals with a Tayloe mixer (aka a Zero IF approach).
Unfortunately, the AD9106 uses a common DDS frequency for all four channels. The standard functionality lets you vary the phase shift and/or amplitude of each channel, but not generate a second frequency. Hence the initial plan above. (I am toying with a notion that it might be possible to manipulate the AD9106 into generating an output which is
offset from the main frequency, but I'm not super confident it's possible.)
I admired the
Teensy-LCR by
WeTec, which tops out around 90 kHz. Moving up to 10 MHz should give me some visibility into the self resonant frequencies of home made transformers etc.
