Too much hassle when there are easy cheap alternatives.Cheap yes, easy no.
Anything that involves soldering is not even remotely comparable to solderless breadboards in terms of easiness for R&D. Nothing beats solderless breadboards for trying different circuits and different part values in hardware quickly and with zero waste.
It's only when you are settled on a specific circuit and component values that proceeding to soldering to build a working prototype makes sense, or, another scenario, when parasitics of the solderless breadboard make it impossible or too unreasonable to use in a specific case.
The world of electronics isn't limited by HF and fast digital circuits. And even for those solderless breadboards can be quite usable, as long as you know what you're doing.You’re absolutely correct. But we can always count on tggzzz to find every mention of the word “breadboard” and inject his absolutist anti-breadboard stance into the discussion. He will never acknowledge or recognize that breadboards have their applications. I’ve tried explaining it multiple times but it’s like talking to a wall, except that walls aren’t as whiny.
That is a clear example of the pot calling the kettle black! Can I suggest you read the thread title and the first post, rather than just being a seagull.
This whole thread is about a problem the OP found using solderless breadboard, which disappeared when they used a better prototype technology.
Q.E.D.
Most people advocate using solderless breadboards so resistors are not disposable, and can be reused.
Q.E.D.We don’t actually know whether it being breadboarded was actually the root cause of the problem. It could be, but it could also be something like an assembly error which the OP didn’t repeat when assembling on perfboard. Or maybe they have a really bad breadboard (which I consistently advise against), which cannot be taken as a reason to avoid breadboards entirely. (That people have bad experiences with, for example, dollar store screwdrivers doesn’t mean people should abandon screws entirely and weld everything. It means they should buy proper quality screwdrivers.)
As always, the issue I take with you is your absolutist stance. Smart people recognize that the world exists in shades of gray, not black and white, and that even tools with limitations have their purpose.
Most people advocate using solderless breadboards so resistors are not disposable, and can be reused.It’s not the cost of resistors that makes breadboarding useful. It’s that saving parts means you don’t run out of them as often (meaning that you don’t find yourself without a part you need, regardless of cost), and it does save money on expensive parts.
It also doesn’t involve heat, which is great for beginners who aren’t great at soldering yet, particularly for unusually heat-sensitive parts.
Thank you for getting round to reading the title and first post…
… and tacitally [sic] admitting that you were doing what you falsely claimed I was doing!
The world certainly is not black and white. However there is a relevant proverb: "the race does not always go to the fastest, but that's the way to bet".
There's validity to that, but a counter-example is that I still have components that I desoldered from boards in the 70s. That makes me smile and shake my head more than it makes me feel proud
Unusually heat sensitive components are, by definintion, an unusual case. Polystyrene caps spring to mind.
Beginners need to start soldering ASAP. It isn't difficult and is a necessary skill, so throw them in at the the deep end, but don't let them sink.
Thank you for getting round to reading the title and first post…I read and understood the OP from the very beginning, before you ever commented.
… and tacitally [sic] admitting that you were doing what you falsely claimed I was doing!I didn’t admit to anything, and no reasonable reading of this thread would perceive it that way. All I stated is that you inject your absolutist stance into every thread you find about breadboarding, and do not in any way EVER entertain the value in breadboards, two claims which are objectively true. You absolutely see this issue as black and white, in that you are of the opinion that breadboards are always worse than the alternatives, in all situations.
The world certainly is not black and white. However there is a relevant proverb: "the race does not always go to the fastest, but that's the way to bet".What on earth does that have to do with anything?
I used to use wire wrap for my digital experiments. The FPGAs did not have the drive strength control we have today. The last board I made ran at a 100MHz. I knew enough by then that getting that board working wasn't too bad. But that is the reason for so many of those series resistors in the DIP packages shown at 9:50 in.
EDIT: after having bothered to look at the 20s of the video you pointed to... just so. Wire length (relative to risetime) is the source of the problem, and peversely adding the DIP resistors increases the length. Anyway...
I like wire-wrap, but the stub antennas are, um, suboptimal. Some production 70s computers were wire-wrapped. Wire-wrapped logic became obsolete by the mid 80s. Wire-wrap wire is still very useful; I have a lifetime's supply.
I suppose I might see a black swan, someday.
Come to Australia, they're all over the place!
Staying with Oz, in support of the "unimpressed with solderless breadboards" argument.
Throughout my career in electronics, I never saw such a breadboard "used in anger".
A few places had one tucked away unused for years, some still in their original unopened packing.
The general opinion amongst both Techs & EEs was that they were overpriced & unreliable.
The EEs usually built prototypes in "spiderweb" fashion, got a nice PCB made & handed it to a Tech to build----and debug, as things seldom worked as well on a PCB as they did "spiderwebbed".
