Yes, the past! Years ago I worked for Burleigh Instruments Inc., who made piezoelectric devices for the scientific and optical world. We made several high voltage amplifier products, all using those Delco high voltage electronic ignition transistors. DTS-723 and some others. Later we used (I think) BU-209 or something similar, probably TV horizontal deflection transistors. Interestingly, you'll find a HV amplifier circuit in Art of Electronics that's near identical to the one we made for decades at Burleigh. They made some minor changes and improvements, but it was obvious at first glance that it was the same circuit. It's actually a totem pole based on low voltage TTL logic, where you have the top transistor charging the load, and the bottom transistor dumping to ground through a diode, pulling the base of the upper transistor down with it. Not so great at high audio frequencies, but surprisingly linear for what it was. Not sure if it could reach 20 kHz or not. Did work great with capacitive loads.
