Yikes, double suicide biased BJTs? BJTs at high voltage, linear? Double yikes!
But yes, the basic idea would be fine; emitter degeneration on Q5 and Q6 makes it a simple transconductance level shifter, and the CCS pull-up gives it high voltage gain (mind, way, way too much gain to close the loop on an op-amp).
Q3-Q4 is problematic especially at high voltages, where Q3 runs away due to raw unbridled Early effect plus self-heating. A cascode is mandatory. For higher voltages, a divider chain between Vcc-Out-Vee (wait why is that "-Vcc" and not "Vee"?..) will be needed; note it doesn't need to be common to the gain node, it can be bootstrapped. One advantage of the follower topology. Which means the outputs themselves can be cascoded on, well it can be the same divider chain really, can't it. So that's not too bad.
I don't get R4 and R5. Something about frequency compensation perhaps (Ccb of Q3, Q6)? (Surely it's not current limiting, a triple-suicide-biased route?)
That said, some resistance in strategic places might go some way to improving robustness, i.e. in event of output short circuit or overload (or teething troubles while testing
). Consider what happens when any given transistor fails shorted, and ensure adequate resistance around to prevent overvolting the remaining parts. Might give some chance of turning it off before the whole thing runs away.
Output also shows class C, which is pretty nasty for audio, even at these voltages. Easily solved with a couple bias diodes, which can be integrated into the cascode divider chain as well, I think.
Can also be made complementary, by mirroring Q5; in that case, both Q6 and Q3-Q4 act as current mirrors; note that Q6 can have more than unity gain, unlike the plain mirror. So that's probably a worthy improvement.
Minimizing voltage swings is mandatory for bandwidth purposes. Consider Q5: it could be turned into a cascode chain, with fixed base voltages, and minimal emitter degeneration (I mean, enough to handle the op-amp's output swing, but little in the stack itself, and a low output (collector) swing (i.e., at R7). As opposed to using series collector resistors (kinda like R4 and R5), which introduce a 1/(R*Ccb) pole, and Ccb is of great importance when so little bias current is available (to minimize power dissipation in these level shifting and driver sections).
Speaking of current, Darlington outputs are generally undesirable for their higher saturation voltage, or perhaps lower bandwidth; but they are probably an excellent idea here, biased properly of course (use some Rbe across the power transistor to bias the driver into reasonable conduction). Who cares about saturation when you have thousands to spare; meanwhile, the higher composite hFE minimizes drive current (which will still be limited by node capacitance and required bandwidth, but the Darlingtons help with this in part, too).
Anyway, that's all assuming BJTs that actually...work, which is a big ask at high voltages. As I recall, there's basically nothing above 400V or so, for linear operation. BJTs are just
terrible at voltage, in linear operation. In particular, you can't find any amplifier transistors over 250V or so; all 1.5kV (or higher) parts are optimized for switching, with
embarrassing SOAs. Anyway, MOSFETs basically drop into most of these positions, with the higher Vgs(th) vs Vbe being irrelevant, and the low Ig a great improvement (assuming, of course, Ciss is manageable, sometimes a hard ask when forced to choose among power switching types). Do include a S-G zener to prevent gate rupture; make sure it's a small part (low capacitance!). BJTs can still be used at the bottoms of cascodes if you like, for higher transconductance or better current matching or what have you; indeed this can be designed to quite a low voltage drop so that say 2N3904/6s do the job, since we're not talking a whole lot of current here in any position.
Ed: Mind, this isn't personal. (I think. I hope?) Note the filename of the above attachment... one should never be surprised what kind of trash may be found on those ezines.
