Hi eevblog,
I recently had a Si5351 hooked up to my spectrum analyzer and took a few measurements. My particular application needs a VHF LO and I was curious how clean the Si5351 is.
Here's a shot centered at 146.72MHz with 25MHz span:
You can see a fairly large spur (-46dBc) offset 3.26MHz on both sides along with a fair number of other signals.
Here's a shot of the first few harmonics:
The second harmonic is -16.1dBc and the third is -11.7dBc.
Lastly, the harmonics out to 3GHz. Still a respectable -36dBm signal way out there at 2.7GHz!
I also took some measurements near 12.2MHz and 5.1MHz and found the situation to be much better. No screenshots unfortunately but there were minimal/no visible spurs at those frequencies.
Hopefully interesting information for some.
