I have been contracted by an employer to build a low and hi end phono pre-amp. I jumped at it thinking this will be easy stuff, being use to RF and faster digital I thought piece of cake. Which it really is I think I am just reading way to much down the Hi-Fi Audiofile rabbit hole....
So it turns out there is no real standard in the record industry to make cartridges or the the magnetic head behind the stylus a standard impeadence, 47k has been a pretty standard value used in most pre-amps but its not always the correct one. For the higher end amp I plan on using an AD chip to just read its impeadence and then match appropriately. On the lower end side I was thinking about just slapping a 100k pot in there with a line on the case at 47k ohms. Then I started reading that you can hear resistor noise and blah blah, is this even true I always thought Johnson noise was so low you couldn't even distinguish it on a scope, I mean were not talking about burning power resistors here, at a few mV a 1/4 watt pott leaves plenty of thermal headroom! Secondly the the cart usually calls for some captive as well as resistive loading, apparently the capactive loading can cause all sorts of problems with frequency roll off if it is not right so why the hell use it at all?
? I mean Xc will vary with frequency while a purely restive load will have a flat response correct? So i would buffer the load then throw a low gain stage at it after which I would use the 100k pot to make sure the insertion loss is in negligible. Apparently buffers are bad and create noise....
? WTF if that were true why would every respectable head phone amp use buff634 chips for current driving?
I would rather just wrap a god damn transformer but audio frequency is so low that it make L circuits cumbersome and I dont know how to make a fully variable transformer anyways, especially in the cheap end model.
My main competitor is this heap of crap....
http://www.amazon.com/Madisson-Preamplifier-Turntable-Amplifier-Pre-Amp/dp/B003UPTE4KOn request I can provide pictures of circuit and reverse schematics when Im done but lets jus say this thing sells becuase of price Im trying to hit 30 dollars. This heap of crap uses a switching supply through a 12v zenez as its main power source with old ceramic disc caps in the audio chain, which we all know have bad piezo effects and no AudioFileBS just arent suitable for audio, dave even has a video on this. The worst part is the opamp has an awful slew rate it is like a dual 741..... common guys. There is nothing in the 30 dollar level right now I dont know about you but I would pay 15 bucks for metalized film at least a long with a real regulated power supply (which will probably use two 9vs to save cost) and an opamp of at least marginal quality like a TI or NE55.
Any intelligent info would be appreciated to me the impeadence loading make all the difference in the acually frequency response and things like crappy RCA files to the amp along with Cart can effect it's level. I am just looking for an inexpensive no bs way to get a flat response before the RIAA eq. Unfortunately Im getting sucked in to this whole dont use buffers you need teflon caps but hey just stick a 47k to ground in there meet load requirements hole. God audio SUCKS!
