Update: I discovered that inserting a bootable USB, and pressing F3 on boot, a selection screen appears and the bootable USB can be chosen.
This only occurs if the (working) Sonicwall CF card is inserted. If the card isn't present, the device won't boot at all.
Anyway, booting into a FreeBSD LiveCD (all I had on hand) gives the following dmsg and pciconf -lvc outputs:
---<<BOOT>>---
Copyright (c) 1992-2019 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 12.1-RELEASE r354233 GENERIC i386
FreeBSD clang version 8.0.1 (tags/RELEASE_801/final 366581) (based on LLVM 8.0.1)
VT(vga): resolution 640x480
CPU: VIA C7 Processor 1800MHz (1795.55-MHz 686-class CPU)
Origin="CentaurHauls" Id=0x6d0 Family=0x6 Model=0xd Stepping=0
Features=0xa7c9bbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,CMOV,PAT,CLFLUSH,ACPI,MMX,FXSR,SSE,SSE2,TM,PBE>
Features2=0x4181<SSE3,EST,TM2,xTPR>
AMD Features=0x100000<NX>
VIA Padlock Features=0xffcc<RNG,AES,AES-CTR,SHA1,SHA256,RSA>
real memory = 2147483648 (2048 MB)
avail memory = 2004865024 (1911 MB)
Event timer "LAPIC" quality 100
ACPI APIC Table: <080509 APIC1155>
arc4random: no preloaded entropy cache
ioapic0 <Version 0.3> irqs 0-23 on motherboard
ioapic1 <Version 0.3> irqs 24-47 on motherboard
Timecounter "TSC" frequency 1795549724 Hz quality 800
random: entropy device external interface
kbd1 at kbdmux0
[ath_hal] loaded
module_register_init: MOD_LOAD (vesa, 0x14d9fb0, 0) error 19
random: registering fast source VIA Nehemiah Padlock RNG
random: fast provider: "VIA Nehemiah Padlock RNG"
nexus0
vtvga0: <VT VGA driver> on motherboard
cryptosoft0: <software crypto> on motherboard
acpi0: <080509 RSDT1155> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
agp0: <VIA 3364 (P4M900) host to PCI bridge> on hostb0
agp0: aperture size is 128M
device_attach: ioapic0 attach returned 6
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> mem 0xf8000000-0xfbffffff,0xfd000000-0xfdffffff irq 16 at device 0.0 on pci1
vgapci0: Boot video device
pcib2: <ACPI PCI-PCI bridge> irq 27 at device 2.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 31 at device 3.0 on pci0
pci3: <ACPI PCI bus> on pcib3
em0: <Intel(R) PRO/1000 Network Connection> port 0xcc00-0xcc3f mem 0xfcfe0000-0xfcffffff,0xfcfc0000-0xfcfdffff irq 21 at device 8.0 on pci0
em0: Invalid MAC address
em0: IFDI_ATTACH_PRE failed 5
device_attach: em0 attach returned 5
em0: <Intel(R) PRO/1000 Network Connection> port 0xc880-0xc8bf mem 0xfcf80000-0xfcf9ffff,0xfcf60000-0xfcf7ffff irq 20 at device 9.0 on pci0
pci0: <encrypt/decrypt, network/computer crypto> at device 10.0 (no driver attached)
atapci0: <VIA ATA controller> port 0xc800-0xc807,0xbc00-0xbc03,0xb880-0xb887,0xb800-0xb803,0xb480-0xb48f mem 0xfcf3fc00-0xfcf3ffff irq 21 at device 15.0 on pci0
ata2: <ATA channel> at channel 0 on atapci0
ata3: <ATA channel> at channel 1 on atapci0
atapci1: <VIA ATA controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xfc00-0xfc0f at device 15.1 on pci0
ata0: <ATA channel> at channel 0 on atapci1
ata1: <ATA channel> at channel 1 on atapci1
uhci0: <VIA 83C572 USB controller> port 0xb000-0xb01f irq 20 at device 16.0 on pci0
uhci0: LegSup = 0xa000
usbus0 on uhci0
uhci1: <VIA 83C572 USB controller> port 0xb080-0xb09f irq 22 at device 16.1 on pci0
uhci1: LegSup = 0xa000
usbus1 on uhci1
uhci2: <VIA 83C572 USB controller> port 0xb400-0xb41f irq 21 at device 16.2 on pci0
uhci2: LegSup = 0xa000
usbus2 on uhci2
ehci0: <VIA VT6202 USB 2.0 controller> mem 0xfcf3f800-0xfcf3f8ff irq 22 at device 16.4 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci0
isab0: <PCI-ISA bridge> at device 17.0 on pci0
isa0: <ISA bus> on isab0
acpi_button0: <Sleep Button> on acpi0
pcib4: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> at device 0.0 on pci4
pci5: <ACPI PCI bus> on pcib5
em0: <Intel(R) PRO/1000 Network Connection> port 0xec00-0xec1f mem 0xfebe0000-0xfebfffff irq 16 at device 0.0 on pci5
pcib6: <ACPI PCI-PCI bridge> at device 0.1 on pci4
pci6: <ACPI PCI bus> on pcib6
em0: <Intel(R) PRO/1000 Network Connection> port 0xdc00-0xdc1f mem 0xfeae0000-0xfeafffff irq 16 at device 0.0 on pci6
acpi_button1: <Power Button> on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbdc0: non-PNP ISA device will be removed from GENERIC in FreeBSD 12.
ppc0: parallel port not found.
est0: <Enhanced SpeedStep Frequency Control> on cpu0
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
ugen0.1: <VIA UHCI root HUB> at usbus0
uhub0: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <VIA UHCI root HUB> at usbus1
uhub1: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <VIA UHCI root HUB> at usbus2
uhub2: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
usbus3: 480Mbps High Speed USB v2.0
ugen3.1: <VIA EHCI root HUB> at usbus3
uhub3: <VIA EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen3.2: <Generic Mass Storage> at usbus3
umass0 on uhub3
umass0: <Generic Mass Storage, class 0/0, rev 2.00/1.00, addr 2> on usbus3
umass0: SCSI over Bulk-Only; quirks = 0xc100
umass0:4:0: Attached to scbus4
(aprobe1:ata0:0:0:0): SETFEATURES SET TRANSFER MODE. ACB: ef 03 00 00 00 40 00 00 00 00 0a 00
(aprobe1:ata0:0:0:0): CAM status: ATA Status Error
(aprobe1:ata0:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT )
(aprobe1:ata0:0:0:0): RES: 51 04 00 00 00 00 00 00 00 0a 00
(aprobe1:ata0:0:0:0): Retrying command, 0 more tries remain
(aprobe1:ata0:0:0:0): Error 5, Retries exhausted
Trying to mount root from ufs:/dev/ufs/FreeBSD_Install [ro,noatime]...
da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
da0: <Generic Flash Disk PMAP> Removable Direct Access SPC-2 SCSI device
da0: Serial Number 19072216524200
da0: 40.000MB/s transfers
da0: 7680MB (15728640 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
ugen3.3: <vendor 0x05e3 USB2.0 Hub> at usbus3
uhub4 on uhub3
uhub4: <vendor 0x05e3 USB2.0 Hub, class 9/0, rev 2.00/32.98, addr 3> on usbus3
uhub4: 4 ports with 4 removable, self powered
random: unblocking device.
ugen3.4: <SIGMACHIP USB Keyboard> at usbus3
ukbd0 on uhub4
ukbd0: <SIGMACHIP USB Keyboard, class 0/0, rev 1.10/1.10, addr 4> on usbus3
kbd2 at ukbd0
lo0: link state changed to UP
uhid0 on uhub4
uhid0: <SIGMACHIP USB Keyboard, class 0/0, rev 1.10/1.10, addr 4> on usbus3
hostb0@pci0:0:0:0: class=0x060000 card=0x03641106 chip=0x03641106 rev=0x00 hdr=0x00
vendor = 'VIA Technologies, Inc.'
device = 'CN896/VN896/P4M900 Host Bridge'
class = bridge
subclass = HOST-PCI
cap 02[80] = AGP v3 8x 4x SBA disabled
cap 01[50] = powerspec 2 supports D0 D3 current D0
hostb1@pci0:0:0:1: class=0x060000 card=0x13641106 chip=0x13641106 rev=0x00 hdr=0x00
class = bridge
subclass = HOST-PCI
hostb2@pci0:0:0:2: class=0x060000 card=0x23641106 chip=0x23641106 rev=0x00 hdr=0x00
class = bridge
subclass = HOST-PCI
hostb3@pci0:0:0:3: class=0x060000 card=0x00000000 chip=0x33641106 rev=0x00 hdr=0x00
class = bridge
subclass = HOST-PCI
hostb4@pci0:0:0:4: class=0x060000 card=0x43641106 chip=0x43641106 rev=0x00 hdr=0x00
class = bridge
subclass = HOST-PCI
none0@pci0:0:0:5: class=0x080020 card=0x53641106 chip=0x53641106 rev=0x00 hdr=0x00
device = 'CN896/VN896/P4M900 I/O APIC Interrupt Controller'
class = base peripheral
subclass = interrupt controller
hostb5@pci0:0:0:6: class=0x060000 card=0x63641106 chip=0x63641106 rev=0x00 hdr=0x00
device = 'CN896/VN896/P4M900 Security Device'
class = bridge
subclass = HOST-PCI
hostb6@pci0:0:0:7: class=0x060000 card=0x00000000 chip=0x73641106 rev=0x00 hdr=0x00
class = bridge
subclass = HOST-PCI
pcib1@pci0:0:1:0: class=0x060400 card=0x00000000 chip=0xb1981106 rev=0x00 hdr=0x01
device = 'VT8237/VX700 PCI Bridge'
class = bridge
subclass = PCI-PCI
cap 01[70] = powerspec 2 supports D0 D3 current D0
pcib2@pci0:0:2:0: class=0x060400 card=0xc3231106 chip=0xa3641106 rev=0x80 hdr=0x01
device = 'CN896/VN896/P4M900 PCI to PCI Bridge Controller'
class = bridge
subclass = PCI-PCI
cap 10[40] = PCI-Express 1 root port max data 128(256) RO NS
link x0(x16) speed 0.0(2.5) ASPM disabled(L0s/L1)
slot 0 power limit 150000 mW HotPlug(empty) surprise
cap 01[68] = powerspec 2 supports D0 D3 current D0
cap 05[70] = MSI supports 1 message, 64 bit
cap 08[88] = HT MSI fixed address window disabled at 0xfee00000
cap 0d[98] = PCI Bridge card=0xc3231106
ecap 0001[100] = AER 1 0 fatal 0 non-fatal 0 corrected
ecap 0002[140] = VC 1 max VC1
ecap 0005[180] = Root Complex Link Declaration 1
pcib3@pci0:0:3:0: class=0x060400 card=0xc3231106 chip=0xc3641106 rev=0x80 hdr=0x01
class = bridge
subclass = PCI-PCI
link x0(x1) speed 0.0(2.5) ASPM disabled(L0s/L1)
none1@pci0:0:8:0: class=0x020000 card=0x107c8086 chip=0x107c8086 rev=0x05 hdr=0x00
vendor = 'Intel Corporation'
device = '82541PI Gigabit Ethernet Controller'
class = network
subclass = ethernet
cap 01[dc] = powerspec 2 supports D0 D3 current D0
cap 07[e4] = PCI-X supports 2048 burst read, 1 split transaction
none2@pci0:0:9:0: class=0x020000 card=0x107c8086 chip=0x107c8086 rev=0x05 hdr=0x00
class = network
subclass = ethernet
none3@pci0:0:10:0: class=0x100000 card=0x0001177d chip=0x0003177d rev=0x00 hdr=0x00
vendor = 'Cavium, Inc.'
device = 'Nitrox XL N1 Lite'
class = encrypt/decrypt
subclass = network/computer crypto
cap 07[e0] = PCI-X 64-bit supports 133MHz, 4096 burst read, 32 split transactions
cap 01[e8] = powerspec 2 supports D0 D3 current D0
cap 05[f0] = MSI supports 1 message, 64 bit
atapci0@pci0:0:15:0: class=0x01018f card=0x52871106 chip=0x52871106 rev=0x20 hdr=0x00
device = 'VT8251 Serial ATA Controller'
class = mass storage
subclass = ATA
cap 01[c0] = powerspec 2 supports D0 D3 current D0
atapci1@pci0:0:15:1: class=0x01018a card=0x05711106 chip=0x05711106 rev=0x07 hdr=0x00
device = 'VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE'
subclass = ATA
uhci0@pci0:0:16:0: class=0x0c0300 card=0x30381106 chip=0x30381106 rev=0x91 hdr=0x00
device = 'VT82xx/62xx UHCI USB 1.1 Controller'
class = serial bus
subclass = USB
cap 01[80] = powerspec 2 supports D0 D1 D2 D3 current D0
uhci1@pci0:0:16:1: class=0x0c0300 card=0x30381106 chip=0x30381106 rev=0x91 hdr=0x00
class = serial bus
subclass = USB
uhci2@pci0:0:16:2: class=0x0c0300 card=0x30381106 chip=0x30381106 rev=0x91 hdr=0x00
class = serial bus
subclass = USB
ehci0@pci0:0:16:4: class=0x0c0320 card=0x31041106 chip=0x31041106 rev=0x90 hdr=0x00
device = 'USB 2.0'
class = serial bus
subclass = USB
cap 0a[88] = EHCI Debug Port at offset 0xa0 in map 0x14
isab0@pci0:0:17:0: class=0x060100 card=0x32871106 chip=0x32871106 rev=0x00 hdr=0x00
device = 'VT8251 PCI to ISA Bridge'
class = bridge
subclass = PCI-ISA
hostb7@pci0:0:17:7: class=0x060000 card=0x287e1106 chip=0x287e1106 rev=0x00 hdr=0x00
device = 'VT8237/8251 Ultra VLINK Controller'
class = bridge
subclass = HOST-PCI
cap 08[58] = HT interrupt
hostb8@pci0:0:19:0: class=0x060000 card=0x00000000 chip=0x287b1106 rev=0x00 hdr=0x00
device = 'VT8251 Host Bridge'
class = bridge
subclass = HOST-PCI
vgapci0@pci0:1:0:0: class=0x030000 card=0x19750908 chip=0x33711106 rev=0x01 hdr=0x00
device = 'CN896/VN896/P4M900 [Chrome 9 HC]'
class = display
subclass = VGA
cap 01[60] = powerspec 2 supports D0 D1 D2 D3 current D0
cap 02[70] = AGP v3 8x 4x SBA disabled
pcib5@pci0:128:0:0: class=0x060400 card=0x00000000 chip=0x287c1106 rev=0x00 hdr=0x01
device = 'VT8251 PCIE Root Port'
class = bridge
subclass = PCI-PCI
link x1(x2) speed 2.5(2.5) ASPM disabled(L0s/L1)
cap 05[70] = MSI supports 1 message, 64 bit, vector masks
cap 0d[90] = PCI Bridge card=0x00000000
pcib6@pci0:128:0:1: class=0x060400 card=0x00000004 chip=0x287d1106 rev=0x00 hdr=0x01
class = bridge
subclass = PCI-PCI
link x1(x1) speed 2.5(2.5) ASPM disabled(L0s/L1)
cap 0d[90] = PCI Bridge card=0x00000004
none4@pci0:130:0:0: class=0x020000 card=0x00008086 chip=0x109a8086 rev=0x00 hdr=0x00
device = '82573L Gigabit Ethernet Controller'
class = network
subclass = ethernet
cap 01[c8] = powerspec 2 supports D0 D3 current D0
cap 05[d0] = MSI supports 1 message, 64 bit
cap 10[e0] = PCI-Express 1 endpoint max data 128(256) RO NS
ecap 0001[100] = AER 1 0 fatal 1 non-fatal 0 corrected
ecap 0003[140] = Serial 1 000000ffff000000
none5@pci0:129:0:0: class=0x020000 card=0x00008086 chip=0x109a8086 rev=0x00 hdr=0x00
class = network
subclass = ethernet
I am wondering if the presence of the Cavium Nitrox is going to be a problem. Obviously this chip isn't going to be supportable, but will the board be usable without it? I wonder. However, all in all, an interesting reverse engineering challenge.
