a plating installation alone costs several 10 thousand dollars. add an imager, a dry film press, a lamination oven , a drill stage and before you have made a single board you are over 100.000$. and that is if you buy used stuff.
then there is the data preprocesing software and expertise you need there.
and the room to put all that equipment
think i'm exaggerating ?
Drill :
http://www.ebay.com/itm/Excellon-Uniline-2000-Machine-w-UCS-Controller-/251164690238?hash=item3a7a95073eand that's a simple one...
the rest of the equipment you can't even find on ebay ...
to make a plated double sided board you need a minimum of
- a cnc drill
- a dry film applying machine
- a photoplotter and exposure unit or LDI machine
- a film developing machine
- a plating setup ( cleaner bath , actuator bath , carbon ink bath , plating bath and plating power supply all interspersed with various drying and washing stages. )
- an electroless tin plating bath
- a film stripper
- an etching system
- a soldermask ink application machine
- a drying oven
- a silkscreen ink application machine using actual silkscreen stencils or printer
- a drying oven
if you want to do 4 layer or more you will also need
a lamination oven
then there is all the chemicals
all the know how to set up the baths and control them
the preprocessing software to prepare the data all these machines need (Genesis Frontline or Ucamco )
if you want to deliver electrically tested boards you will need a flying probe machine and or a bed of nails tester.
you may also want to invest in an AOI machine
and to deliver the boards you will need a final board milling / depanelisation machine and possible a v-scoring machine
add in a vacuum pack setup and a source of various laminates and a wastewater treatment plant and you are looking at a million dollars.
without building and or permits for all your chemicals and waste handling
in short : can't be done. Not at your set budget , not without the appropriate know how.
I am thinking of spending a few thousand dollars
Clearly you got no clue ...
I likely won't be able to do high frequency RF or boards having more than a few layers
RF boards are no different process than others. As 'technologist' you should know this. Only the substrate material changes.
As for the layers ... for a few thousand dollars you'll be able to make singlesided boards or non plated double sided without masks. Anything beyond that is out of reach.
I have plenty of free time, so the equipment not need be very efficient, as long as it gives very high quality product I am ok.
High quality ? Today 'chinese' boards are even run on LDI machines and those start at 200K US $ ...
Electronics Engineering Technologist
-cough- riiiight ...
