Author Topic: Connector name?  (Read 1274 times)
Offline salviadorTopic starter
    • https://www.youtube.com/user/mancio92M
Connector name?
« on: January 30, 2017, 10:44:47 am »
How is called the black connector?
It is mounted sulla hoverboard engine
Offline CM800
Re: Connector name?
« Reply #1 on: January 30, 2017, 12:17:19 pm »
The best thing you can do is go onto Farnell or Mouser, go to their connectors page
Select all connectors with the same pin pitch & number of contacts
then select the specific manufactuer (if it is printed on the connector)
then look through the list for ones the look similar and compare. It's what I usually do and I've got a pretty good track record doing it.
Offline KMoffett
Re: Connector name?
« Reply #2 on: January 30, 2017, 09:05:25 pm »
Looks like automotive connectors. But since your picture came from a scooter page that would be a search term. The ones on the right are referred to as male bullet connectors. The ones on the left are referred to as modular connectors here: https://www.google.com/search?q=scooter+connectors&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiel_qv4erRAhUI6mMKHXe3Bz4Q_AUICSgC&biw=1489&bih=887#imgrc=88dpQ97ZsXj0JM%3A
Ken
