Dimensions can be found in EasyEDA pro editor. Tried to do it on a smartphone, but menu doesn't work or too small. On a PC you can create a new EasyEDA pro project, in schematics select Placement - reuse block/device, search for this connector, select it from the list and then press "place" button. After placement, use menu to convert schematic to PCB and then use the ruler. Or draw a small rectangle and compare it's dimensions with the hole. It's probably not the best way an I am new to EasyEDA pro. There are also circular cutouts in the board!
