Attached below is a schematic of a kind of regulated 15V power supply (don't mind the use of the LM2931, it only serves as a low drop-out voltage reference and as a overtemperature limit). I added a current limiting circuit for overcurrent protection (mainly for Q5 and Q7).
If C7 is not present, it works as intended, but I want to allow for short current spikes which wouldn't damage Q5 and Q7. I thus thought of slowing down the feedback loop by adding R22 and C7. If I do that, the circuit becomes unstable (current oscillates between 3 and 10A for a load of 1.5 Ohms).
Before I do the full small signal loop analysis to see where the unstability is coming from and where to put R22/C7 instead, is there an obvious way to do what I'm trying to do while staying stable?
Thanks
