I am looking for a recommendation on a full dual function generator that is sold as reasonable lab equipment to plagiarize the analog front end of.
I need a function generator that can go up to 5-15MHz and has dual outputs.
I basically need a lab tool that can phase shift two sine/triangle waveforms (and have all the FG adjustments). But this lab tool would be used infrequently. I figure so long I don't want to pay for the bells and whistles I can make the analog front end fairly cheap (for a machine that normally costs 2000$+) and then program a micro controller to configure the DDS chip, I just need to test a few patterns.
I assume that rigol uses one of those AD dds chips, I just want a tried and true build around them with no guess work. I don't want to design a function gen, but I need this capability to test another project and determine if its needed in another project.
