It works "anyway", because the parts he has used, appear as a voltage source within the required spec and a series resistance of about 200 ohms. He changes the series resistor in the circuit from 1 kohms to 820 ohms to compensate. The problem is, this characterization of the part is not assured, since it's not in the data sheet. Tomorrow, the next batch of parts may only drive to 11.0V or 10.5V or even 9V which is all you can assure from the data sheet!
Ok... but those variances can be tested. They are observable. A sampling will show them. I don't know what's so mysterious about your as-yet unexplained "process" that's so untestable here? Surely you must be using a different meaning of "process" than what is coming to my mind?
Why would I want to test parts before I use them? There's incoming inspection, but who actually mounts their parts in a chip tester to repeat the testing that was done at the factory? For many devices, such as op amps, the testing is the lion's share of the costs.
This is what I'm talking about. People are coming up with all manner of excuses for this design, instead of just
fixing it!Framing it in terms of design by contract: there are always three aspects to a contract. There's what the client party thinks they should be getting; there's what the supplier party thinks they should be making; and there's verification -- each party being able to prove to each other that the steps and clauses of that contract have been met, to mutually agreed satisfaction. Clauses without verification are as good as struck, and clauses that are overly specific for their testing methods are only as good as the test itself. It comes down to design-for-test (in analogy to "teach to the test" schooling). That doesn't have to be a bad thing (as that analogy often connotates), but it means we have a responsibility to design our contracts, or standards, or whatever, to a high level. And if we fail to do so, it is our own fault, whether through lack of foresight, laziness, or lack of responsibility/wherewithal to update the standard at a later date to correct those shortcomings (which, yes, can have many issues about it, but it almost always comes down to "political will", being able to convince enough people of the value of the change, and then to push that change to all stakeholders).
Are you a lawyer... being paid by the word? Can you say this part in 20 words or less?
Beats me. You're insisting upon "standards" and "process"... If you're that committed to standards, I'd have thought the verbosity would be appreciated? Are you not actually, then..?
I believe I've referred to the J1772 standard, which is the reason for this design existing. I've referred to the specification of the LF353, which is the document that should guide the part's use. The "process" I'm referring to is the semiconductor "recipe" used to make the parts, that can not be perfectly controlled and results in variations, or is intentionally modified for some reason, which results in changes in the device, which are not reported as long as the device continues to meet the data sheet. Your assertion about verbosity is absurd. Clearly, you have nothing further to contribute to this conversation.
