Hi all,
I'm building a DIY box with some pretty serious amp modules in it.
There will be two modules, with the spec:
100-240 V AC, 50-60Hz
AC Current Avg / Short Term: Nominal 4A / Max 25A
Inrush Current (230 V AC): 41A peak
I'd like a nice on/off switch on the front of the box.
I had a quick look (even though I imagined something wouldn't exist) for a power switch rated high enough and I couldn't see anything rated high enough for 2 x the above specs, or anything that really looked 'nice' at high current ratings.
So I had the idea of using a big relay?
I've never had to spec a relay to switch mains before, how much should it be over-rated for reliability?
Is there a pretty standard way to enable the relay that would allow the box to be turned fully off (0W power use), when it's off?
Could the mains be switched through a low power, nice looking switch to enable the high power relay that would power up the modules?
Thanks,
G
